ABD connect will not complete publishing of imodels on my current project. see message centre errors below.
It does not tell me which model the errors are in, so how am I supposed to find and rectify??
Unable to publish business data for element XXXX -
SS6 will complete the publishing, but then that makes me wonder whether all info is actually being exported with it.
I am creating these for sharing and federation/clash detection purposes so I need assurance that an imodel(or idgn) is refelctive of my live dgn's
Hi Duncan,
What is the version of ABD Connect Edition you have?
10.0.0.154
If you need to verify the imodel published from SS6 is correct you can use Bentley View:
https://www.bentley.com/en/products/product-line/modeling-and-visualization-software/bentley-view
I did a few tests with some files and so far the publish imodel is working properly on AECOsim Connect Edition, what I can try is test your files in house to see if I get the same results, could you provide me with the sample files ?
Hello Gerard. We are having the same issue for publishing imodels ONLY in some machines. I've tried copying the prefs folder from a workstation that could publish correctly with no success. We are using OpenBuildings CE 10.6.0.64 (last version). Do you happen to know why this might be?
Thanks in advance!
Hi Ignacio,
This is a fairly old thread so there could have been any number of changes since then. However, it may be best to start a new thread and include any details you can, including the version as you did here, but also information about the workspace and any differences between these machines.
