How many End Type Connection in Mechanical AECOsim Building Designer V8i SS5 ?
how can i create my own end type connection with complected shape like Victaulic connection in the firefighting system?
Victaulic Coupling
Hi DMA,
There are only two end types available in AECOsim. But there is a way to make your own custom components. You can create your own coupling and then place it in conjunction with other pipes and/or components with their individual end types as "-;-;".
Please let me know if it helps.
Satadal.
first of all thank you very much Satadal for your reply and for videos
the shape of the output from video is very simple
how can i define the complicated dimension for victaulic shape for example.
if you have ready samples for complicated shape can you provide?
regards
Does this video help?
sure it is help
But i need how can i define this complicated coupling shape in the cell model and connection point file.
for example i have the cell shapes and i want use it automatically in the software!
If you can share the 3D model of this coupling, then I can show you how you can use this as a cell and define the connection points for this one.
As an alternative, you can also share the appropriate 2D views with dimensions for me to create the 3D and then use it as cell with all the connection points.
In case you want to go into deeper further discussion regarding this, you can raise a Service Request. We will communicate with you ASAP and work on your requirement.
