Issue:
i am trying to find command to delete specific attribute and another command to add specific attribute on a specific Tag set for more than 100 files (it will take alot of time if i open file by file and make these editing in each file)
i use record macro but i cant found the command of deleting attribute or adding attribute
this is the command to open tag set (CadInputQueue.SendKeyin "MDL SILENTLOAD TAGS DEFINE")
can any one help me ?
the below two picture to illustrate what i want.
Hi DMA,
I have consolidated the solution information and posted as a Wiki. You can refer to this wiki in future.
Satadal.
