Hello Good ABD Fellas,
I want to know if this wonderful tool called "Add Instance Data" is somehow available in the ABD Connect Edition.
Because I would like to model using solids and other elements, and later be able to give it a catalog definition.
Best Regards
Rafael
Hi Rafael,
The "Add Instance Data" tool is re-named as the "Attach" tool in the ABD CONNECT Edition. This one is available in the Data panel of the Data/Reporting tab of the Ribbon.
Here is a picture of it:
Hope it helps.
Satadal.
Answer Verified By: Rafael Bombardiere Carvajal
I don't know who you are Satadal Dhar, but you must be a Master of AECOsim,
Thank you for your answer
This really helped me :)
I am really glad to know that suggestion from Satadal has helped you. I would request you to verify this answer, so that, other users will be able to find it easily.
Warm Regards,
Subhamoy Kundu
