I have just installed the release version of ABD CE. There was no option to install a specific dataset. Thus I have a US only. I cannot see in the downlaod area where they are stored.....
How can I get the GB or UK versions.?
Ian
Ian, you can follow the video in this Wiki for how to install any other datasets in ABD CE
https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/36107/connect-edition---how-to-download-and-install-different-dataset-for-aecosim-building-designer
During installation the Configure Option (mentioned in Help documentation several wikis about CONNECT Edition installation) incudes an additional dialog for ABD where the datasets are selected.
Marc
Cheers Marc
In my opinion most users (99%) will not read the read me's. Thus, I think changing the installer to show where to change the dataset is a must.
when I pointed out my v5 version of OBD Connect had problems with the plumbing catalogs I was advised to remove all previous versions loaded and re-install from scratch
faithfully I did as told hoping the advice was a tested and proven response to known problems
I have got to say I am not surprised the advice not only failed to solve the problem, but not I don't have a UK dataset or a metric neutral dataset. rendering the time spent a complete waste of time.
its a shame the software has got to the point where it is so poor that none of the actual users have a good word to say about it anymore
David Turner
MEP 3D coordination & BIM Technician
Rail Projects
Hi David,
Please install Datasets following the steps mentioned in this Wiki:
This is the way to install Datasets in the CONNECT Edition, which is different from the V8i workflow.
Please check and find if your problem still persists,
Tathagata
