I have just installed the release version of ABD CE. There was no option to install a specific dataset. Thus I have a US only. I cannot see in the downlaod area where they are stored.....
How can I get the GB or UK versions.?
Ian
On 9 Mar 2020, at 18:33, Tathagata Saha <bounce-86b766b7-670d-48f7-8994-1f8d2c4877a1@communities.bentley.com> wrote:
 <Bentley_5F00_Communities_5F00_RGB_5F00_Stacked_5F00_244x88-png_2D00_125x44-png> Update from Bentley Communities <4U3KUWURBSB3-jpg_2D00_70x70x2-jpg> Tathagata Saha Hi David, Please install Datasets following the steps mentioned in this Wiki: https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/36107/connect-edition---how-to-download-and-install-different-dataset-for-aecosim-building-designer This is the way to install Datasets in the CONNECT Edition, which is different from the V8i workflow. Please check and find if your problem still persists, Regards, Tathagata View online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here. Flag this post as spam/abuse.
Hi David,
Tathagata
View online
David Turner
MEP 3D coordination & BIM Technician
Rail Projects
This is what I see when placing a pipe in Update 6 with the UK dataset:
On 18 Mar 2020, at 22:56, Steve Cocchi <bounce-F54ABBBE-F4D0-4BA1-889A-573A58D91E88@communities.bentley.com> wrote:
 <Bentley_5F00_Communities_5F00_RGB_5F00_Stacked_5F00_244x88-png_2D00_125x44-png> Update from Bentley Communities <4TFHLUYVRQG4-jpg_2D00_70x70x2-jpg> Steve Cocchi Hi David, This is what I see when placing a pipe in Update 6 with the UK dataset: <Place+Pipe+U6+w+UK+dataset-png_2D00_320x240-png> View online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here. Flag this post as spam/abuse.
Exactly. A simple command or function would resolve this. I'm still trying to find out how to attach it although I know the location. There doesn't appear to be a .exe file
Hi Stuart,
info linked on your other thread.
The datasets are downloaded on demand by the installer.
Marc
