Hello everyone, just wanted some advice on a fairly simple procedure that I am always finding myself having to find a work-around to do on the go. Say I wanted to put a toilet between two wall partitions at exactly half way between both walls. Since the half/division marker is only created for the entire length of wall, previously I would have to either draw a line between the two points and snap to the line's half way point, or measure the distance, divide by two, and go off one of the two points. What is the quickest/easiest way to get a snap-point along a straight line/wall, exactly half way between two objects that connect to that line/wall?
Thank you in advance.
Point at the first side, and set your accudraw origin there using the 'O' button.
then point at the other side, and use "/2" to divide the indicated in the accudraw (X, Y or Z value) by 2.
(You can also make other calculations (+-/*) in the accudraw dialog, it saves some time)
Windows 10 pro
OpenBuildings Designer Connect Edition 2023 | 23.00.00.114
you have posted your question in the German Building Forum. To get a quicker response and not have to wait till the Germans begin working and move it to the English Forum, please post your EN Building questions here: AECOsim | speedikon Forum
I will move your post now to the English Forum.
You can bookmark this link for the English Building Forum in your Community Profile or your Internet Browser:
https://communities.bentley.com/products/building/building_analysis___design/f/aecosim-speedikon-forum
Also please enter your Product, used Dataset and Version Number in every Post. Thank you.
Kind Regards
Here you can find many hints about the AccuDraw:
AccuDraw - Drawing Aids - MicroStation
Specially about the calculator:
Pop-up calculator in AccuDraw
S. Janku
Answer Verified By: Artur Goldsweer
You could also use the AccuDraw 'K' shortcut, set the number to 2, the midpoint of the wall will then be a snap point, or just use the MidPoint snap.
Marc
Got it.! Thank you very much.
