Where can I find the Section File Manager dialog to load section definition files in ABD CONNECT?
Now I only can select loaded codes but no chance to open the Section File Manager dialog:
Thank you
Sergi
Sergi, you can use the key-in, TFSECMGR DIALOG, in ABD CONNECT Edition to load the Section File Manager.
There is no access via any menu as it was in V8i?
Sergi Ferrater
Yes, I do not see any access to the Section File Manager dialog other than with the keyin. I will look further into it and file a defect if needed.
There is a new option on the backstage menu (File --> Settings --> Building) called "Section Picker" to run this tool
Eduardo
Answer Verified By: Steve Cocchi
Yes!
Gracias Eduardo!
