I am looking for the physical Parts and Family Dataset file in my C: Drive to so I can back it up before I play around with the settings.
Could someone please tell me the name of the file / its location so I can find it.
Thank you.
The 1%
If you open Dataset Explorer (V8i)/Family?Part Editor (CE) and expand the tree structure in the left hand panel that will show you all of the active locations of the families and parts. They are stored in xml files in the delivered dataset and in each project (V8i) or WorkSet (CE).
You can experiment with changing them in a project/WorkSet without affecting the delivered dataset.
Which version are you running?
Marc
