Hello, I have a problem with parametric cells.
For example, the parametric cell delivered with AECOsim CE with the name Stairs, in folder
C:\ProgramData\Bentley\AECOsim CONNECT Edition\Configuration\WorkSpaces\Example\WorkSets\MetroStation\DGN\Parametric Models
I can't see the steps in the variations. There are always four steps. There should be more steps.
See image
What is the problem?
In the Microstation CE the same cell is correct.
Thank you
Joaquín
AECOsim 10.00.00.154
Joaquin,
when you say this cell works in MicroStation Connect edition this maybe due to a functional difference between the version of Microstation, AECOsim was delivered on and the version of MS you have installed . There have been a number of updates to MS CE since ABD CE was released. This may account for the difference but i will check also,
Brenden Roche
Applications Engineer
Bentley Systems, Manchester UK
Hello Brenden, thank you for your help.
Perhaps, the problem is related to Problem with linked variables in AECOsim CE
Hi Joaquin,
This also works as expected in ABD CE Update 1.
Marc
Answer Verified By: Joaquin
Hello Marc, thank you for this information.
This is a good news
Regars
