I am having problem with handling of DWG file with AECOsim. When I open a DWG file from AECOsim, it does not show all the objects, some of them are missing. But when the same file is opened with another machine it shows all the objects. I suspect there is some kind of settings not quite right on my machine. Could you find out what could be solution for this kind of problem. I am using AECOsim Building Designer (SS6).
you have posted your question in the German Building Forum. To get a quicker response and not have to wait till the Germans begin working and move it to the International Forum, please post your non German Building questions here: AECOsim | speedikon Forum I will move your post now to the International Forum.You can bookmark this link for the International Building Forum in your Community Profile or your Internet Browser:
https://communities.bentley.com/products/building/building_analysis___design/f/aecosim-speedikon-forum
Also please enter your Product, used Dataset and Version Number in every Post. Thank you.Kind RegardsS. Janku
Please can you tell us more about the missing objects? Are they content that may require specific DWG object enablers to ne present? Screenshots from both machines showing the differences may help to illustrate the problem.
Marc
Hi Marc, Thank you for your response. I have now installed Connect Edition version of AECOsim and with this version I can now see all the DWG object.
Answer Verified By: Steve Cocchi
That's good news!
