Hello, I have a problem with linked variable in the extrusion block
I extrude the rectangle.
Afther I linked variable in the distance property. Distance is height = 2 meters.
See image.
This is correct.
Afther, I change the variable Height = 13 meters.
The distance of extrude is the same (Height =2 meters) because the linked this property is missing.
See image
Why occurre this problem?
The same problem with all solid features (array,cut, filled,etc)
With this problem, in AECOsim CE is not possible create parametric solids and parametric cells
In Microstation this is correct. See video (8:37) https://www.youtube.com/watch?v=g9t4FXuYVGw
Thank you
Joaquín
AECOsim CE 10.00.00.154
Hi Joaquín,
ABD CE Update 1 (Bentley internal test build) behaves in the same way as MicroStation, ABD CE Update 1 is due to be available soon.
Marc
Answer Verified By: Joaquin
Hello Marc, thank you for this information.
This is a good news
Regars
