How do I adjust the height of the 2D plan representation of the escalator? My slab has low points and after placing the escalator the 2D representation is embedded in the slab.
I'm creating a plan view (DV) from the level above where the escalators are placed. I've went into the parametric studio and found the escalator.paz cell but I'm unable to adjust the height of the 2D plan.
In which version of ABD are you facing this issue?
Hi Gerard,
The escalator symbol, like most components, is a Cut Plane drawing symbol and will be generated at the Cut Plane location. So if your callout is literally cutting across the slab, then the symbol will be generated at that elevation.
