Whenever I tried to export a DGN file to DWG file I get an error message stating "Unable to open seed file: seed.dwg". Could you help me to solve my problem.
Hi,you have posted your question in the German Building Forum. To get a quicker response and not have to wait till the Germans begin working and move it to the International Forum, please post your non German Building questions here: AECOsim | speedikon Forum I will move your post now to the International Forum.You can bookmark this link for the International Building Forum in your Community Profile or your Internet Browser:https://communities.bentley.com/products/building/building_analysis___design/f/aecosim-speedikon-forumAlso please enter your Product, used Dataset and Version Number in every Post. Thank you.Kind RegardsS. Janku
Under the save as options navigate to the Bentleys standard seed file folder and choose the seed.dwg.
This happens if you have changed some seed file configuration variables usually using and own projects configuration
Frank
