Hello, in the ABD connect edition it is not possible anymore to cut architectural objects like walls, slabs, roofs, with the command 'cut solids by curves' Why isn't this possible anymore? How do I cut holes through these architectural elements?
Marc,
I believe that command is located in the Draw on Solid pull-down under the Modify tab in the Ribbon bar -
Please let me know if this isn't the tool you're looking for.
Larry
Answer Verified By: Steve Cocchi
Update from Bentley Communities [AUTOMATED MESSAGE; if there is a link below, please follow that if you wish to respond to this Communities message.] RE: Why isn't this possible anymore to cut holes through architectural elements in ABD Connect Edition? Larry Abla Marc, I believe that command is located under the Modify tab in the Ribbon bar - Please let me know if this isn't the tool you're looking for. Larry Did this answer your question? Verify it as the answer or Reject it as the answer View online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here. Flag this post as spam/abuse.
View online
