AECOsim SS4
Isometric view is "Illustration with Shadows"
The curved slab forms are displaying faceted.
Printing ok but display looks awful.
Is there a setting I can change ?
FraserG,
Here is what I got using Place Slab - Flood.
Does yours look different?
Larry
Mine looks like a hexagon. I extruded a circle.
Could you upload a screen capture?
Did you use Extrude Shape to Slab Form tool? That has a Tolerance setting in it which will affect any faceting in curves.
I just used the Solid By Profile - Solid By Extrusion command
And this is my result
