Hi
I have AECOsim installed but only Architectural, Structural and HVAC modeler tools is available. Under Electrical there is no modeler tools availble, why is this? Do I need to download additional software ?
Ockert
No, you should be able to load Electrical from the menu, Building Designer > Load Electrical and then you will have all the electrical tasks and tools.
Answer Verified By: Ockert Meyer
In AECOsim Building Designer Connect Edition, you will need to load Electrical from the Electrical tab of the Ribbon and then you will need to select the Register File command in order to see the Electrical Modeling tools.
In v8i, after loading Electrical, you will still need to register the active file before the Electrical tools will function.
Ockert,
Here's a Wiki article with the steps included.
https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/35738/connect-edition---loading-the-electrical-commands
