I created a space and I would like to know the volume of my room ? we have area and ceiling height ...
The goal is to have the volume in label !
someone can help me
thanks
Hi Joel,
We don't store the space volume in the DataGroup system, nor do we support calculations of properties within the DataGroup, so I can't immediately see a way to add the volume to a space label.
It would be possible to add calculations to an Excel schedule and insert that into a drawing.
Marc
thanks for your answer Marc,
ok I did with export and import in excel schedule it's a good solution,
but it's a little frustrating because I have the volume in solibri when I export in IFC ...
regards
Joel
When you select the Space volume, does the Mstn Properties Panel display its volume?
If so, you should be able to use Fields to annotate the volume. The Field could be part of the Cell that Aecosim uses.
You will need to check whether it gets wiped when the Annotation Cell gets updated.
The Advanced Space Label should show the Volume. It use a VBA to calculate the Volume as you see in the picture below
thanks !
