Hi ,
When I upgrade my software to AECOsim CONNECT EDITION, my existing files can not display font 65.
how to overwrite the font library?
Eileen
What is your configuration variable set to in AECOsim CONNECT EDITION ? Path or list of paths that contain RSC, SHX, or TrueType font files. (MS_FONTPATH)
If you take your font.rsc file from your old installation and make sure it is in the path of the new configuration variable, it should read all the same fonts.
Answer Verified By: EILEEN LEE
Hi Robert,
I have copy my font.rsc file to the following floder "C:\Program Files\Bentley\AECOsim CONNECT Edition\AECOsimBuildingDesigner\Default\fonts\" and restart the computer, but I still unable to see the font 65.
Attach image files for your information.
You might see if you can isolate the font by using the Font Utilities to move it from one rsc file to another or at least see that it shows it in the list of fonts. Check this link for more information on that.
https://communities.bentley.com/products/microstation/w/microstation__wiki/8748/edit-font-rsc-font-utilities
I have try up the method, but the font library is RSC file, it is not recognise by Connect Edition software Instead, SHX file is shown . Therefore, this method cannot be used. Or can I know where can I find the RSC file in the Connect Edition.
I have found out that there is a mistake when I override my RSC file. I have successfully inserted the font in my connect edition.
Thank you so much in helping me.
Answer Verified By: Steve Cocchi
