Updating Annotation Cells
Ok to update a Annotation Cell, I know to open the .cel file that has the annotation cell in it and then update the cell that I need to update. is that the correct way or is there another way?
  • Good Question - Actually, if you're editing Datagroup annotations and their associated cells, the best method is to edit them through the Manage Datagroup Annotations Cells tool. This will automatically open the annotation cell library (bb_Annoatation.cel) and provide you a dialog that helps you manage the cells and the associated Datagroup attributes. The Manage Datagroup Annotations Cells is located in the Building Annotations tools box which can be found from the file menu Architecture>Tool Frames>Generic Tools>Annotations. It can also be found in the Architecture task navigation (if you are in a 2D Sheet Model) Under Reference Symbols>Manage datagroup Annotations or keyin: dgannotation manage. I have attached an image of what you are looking for. Hope this helps.
    Jeff Ashley,
    Associate Product Manager, Bentley Architecture
