Hi All,
Generally, I like the profile tool in Aecosim - mostly parametric and easily updated and it is one of the few tools that actually seem to function as needed (well mostly).
However, one very frustrating thing I find about them is that any features (cuts/subtrations etc.) get wiped from the element if after using the modify tool to edit them.
This is obviously ridiculous. So, unless someone can point out where I am doing something wrong, this must be fixed as a priority.
I assume profiles are form-based elements. If so, I suspect this is not the only element to suffer from this problem.
btw this is on SS6 (sorry still haven't committed to updating to CE - not until it is really worth it)
Cheers,
Please can you tell us which tools you are using to modify your profiles?
Marc
thanks for the response. this occurs when using the 'Modify Properties' tool.
AECOsim SS6 + CONNECT U4, Windows 7 Pro, 64Bit, Intel Xeon E3-1275 v5 @ 3.6GHz, 32GB RAM, NVIDIA Quadro P1000
Marc, did you get a chance to look into this?
Hi Joey,
We are looking into this...
