WHAT IS THE ISSUE THAT MY SOFTWARE NOT WORKING
Are you launching AECOsim by double-clicking a DGN file? If so please try opening AECOsim first,then if it opens correctly try creating a new file.
If AECOsim does not open please try a Repair installation and let us know if that resolves the problem.
The 'Abort/Retry/Ignore' dialog normally appears when the application detects a problem that may cause corruption of the active file and is generally a problem with a specific file rather than the whole application.
Marc
Might this apply? If so, please update Office.
https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/36705/microsoft-office-365-august-updates-version-1707-are-causing-crashes-in-aecosim-building-designer-on-startup
Larry
I welcome everyone! Perhaps you really should update your Office, it is. But the problem is that a lot of people often face the fact that applications do not work correctly and may give errors. On this you can lose a lot of time, working time, which brings you income. Agree that this is a sad alternative. Therefore, I advise you to contact the dedicated development team if you ever decide to make your own application!
Tagline Infotech is the most reputable Ruby on Rails Development Company that will provide fully featured RoR solutions.
