Hi Guys,
Im a new user of this software, hope someone can help with this problem.
Im trying to create a custom section (Concrete Super-T) but I can t get it right, Im using a spreadsheet then exporting it on the xml file.
I want to create this section (refer image below)
but im not sure if Im inputting the values on the right place. see spreadsheet table below
Hope someone can help,
Thanks in advance
Jp
What kind of output is getting generated by using these values?
Im trying to create a Super-T cross section (see image), Im not sure if Im putting the right values on the right columns of the table
Which existing section type are you using as a template, and from which regional section XML file?
Im using the template for Precast Concrete Super-T
If you open the StructuralShapesTemplate.xls fpund in your regional dataset, e.g.:
"C:\ProgramData\Bentley\AECOsim CONNECT Edition\Configuration\Datasets\Dataset_US\Data\StructuralShapesTemplate.xls"
you will find each structural section has an illustration showing the value names and locations:
Marc
