I need to install AECOSIM building designer connect editionI am using Windows 7 32 bitAny requirements to system and any suggestions iam from India.Thank you
64-bit applications do not run on 32-bit Windows, I recommend that you investigate upgrading your OS to 64-bit.
Marc
