I am unable to produce quantities in ABD CE. ABD crashes after the error list is produced and is unable to output to excel.
In which build are you facing this?
Hi Duncan
FWIW, an "access violation" error can sometimes infer that permissions are coming into play. If you haven't already, try changing the export location.
tried this already Steve. works for me in SS6, not connect
Hi Duncan,
I see that Tathagata is working with you on this one, but I did want to throw something else out there - are you using any macros in Excel? Since there is a hand-off between AECOsim and Excel I wonder if the error is stemming from the Excel side of the fence.
Thought about and tried that Steve. no difference
Ah well, it was worth a shot! You mentioned that the Quantify tool works for you in Ss6, so there must be some difference between it and CONNECT Editions. Hopefully you and Tathagata can work out what that is!
