Updating Doors in Parametric Cell Studio
When modifiying and/or building new doors in PCS you can put an Elevation Door Swing Marker onto the door so that when it is extracted in bentley it will show which direction the door is to open. Is it poosible, and if so, how do you change the Elevation Door Swing Marker from a solid line to a dashed line. I have made a new part for the component says to to make it dashed but that has not seemed to work. Any suggestions would be great.
  • You are probaly applying the part to the wrong instance of the swing.  That is a complicaiton of PCS as it is a little flacky.  Keep "right clicking on the item.
    Ustn since 1988
    SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64b
    Eric D. Milberger
    Architect + Master Planner + BIM
    Senior  Master Planner NASA - Marshall Space Flight Center
    The Milberger Architectural Group, llc
Reply
    Ustn since 1988
    Eric D. Milberger
