It was not clear how to add comment under Wiki post about reinstall / uninstall errors. This is link to Wiki Post.
https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/22356/cannot-reinstalluninstall-aecosim-building-designer-ss5?CommentId=231944e2-8e52-4409-a209-1ce58b0741f1
Post references Microsoft's Fix It program except link is no longer valid.
I was able to find program here.
https://support.microsoft.com/en-us/help/17588/fix-problems-that-block-programs-from-being-installed-or-removed
After running program, uninstall issue described went away. (And it did not require me to purchase it)
Tom
Tom,
I don't find any broken links in the article you specified above.
Maybe it's already fixed, or you might try doing <Ctrl>F5 in your browser to refresh your cached pages.
Larry
Answer Verified By: Steve Cocchi
My bad Larry,
I was actually typing the link indicated on problem computer and not clicking on link.
Underlying link must have been corrected.
