With the Parametric Frame Builder it used to be possible to attached a part definition to a geometry of window (frame, leaf, pane,...) by using the command "Set Part".
In the latest AECO Sim Connect update 2 the command "Set Part" has no effect on the geometry. Also no part description or not even the part symbology.
Wim
Yes, you are correct. I noticed that when Set Part is applied with a Family and Part to any of the geometry of a frame, even if it is built into it, the Part definition does not display in the Frame Builder. You can place the frame and then Identify it to edit from the Building Information tool. The Frame Builder does not keep the Part definition. I filed Defect 803174:Set Part does not keep the Part definition in Frame Builder
Thanks Robert!
Answer Verified By: wysiwyg
