I'm trying to create a grid system for three different buildings but I keep receiving an error? The following exception occurred in the DataGridView: System.ArgumentException: DataGridViewComboBoxCell value is not valid. To replace this default dialog please handle the DataError event.
Thank you guys for your responses. We had an overzealous CAD manager who created certain permissions to individual files. (managed PW workspace) once I changed my permission to the grid file I was able to edit the file.
But I would like to know, Do you have to set up the floor manger first before creating the grid system?
Ah good to hear it was that simple.
Yes, the grids are generated by each floor. The floors to which the grids apply can be changed when necessary as the project proceeds. You can also apply different grids to groups of floors, e.g. lower floors may have larger floor plates than upper floors. We have tried to cover many possible options based on examples from a number of our users with quite demanding use cases. Note there is also the sketch grid option for irregular grids.
Marc
Answer Verified By: Gerard Georges
when setting up the floor manager, is it best to give each floor an elevation or use the rel. elevation from one known elevation?
