someone can help me !
I've to do a reporting (xls) of my MEP installation, I need a classification by room (space)
thanks
Hi Joel,
Which elements are you wanting to associate with the spaces?
Marc
Hi Marc,
diffusers, ducts, pipes etc...
for electrical (light, detectors ...) is it better to use export in electrical module?
While there is no explicit relationship between mechanical components and spaces, you could select the components within the applicable space (along with the space itself) and use the "Show Only Selection Set" option:
https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/23088/loading-only-selected-objects-within-datagroup-explorer
If you wanted to get a bit more involved, you could also create a custom multi-category schedule:
https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/21027/creating-custom-schedule-report
Answer Verified By: Steve Cocchi
The multi-category schedule is perfect for me ! easy to use ... thanks
You're welcome!
