I am please to announce that the following datasets for Bentley Architecture V8i are now available from SELECT downloads under 'Enhancements and Updates':
Others to follow shortly.
Compared with versions 08.09.05, these 08.11.05 versions includes the following changes:
For a complete list, please see the 'What's New' section in the Readme file.
Kind regards,
Volker
I have just installed the ANZ Dataset, and found a big problem.
In the WorkSpace\TriForma\ArchDatasetUniclassGB\data, there are 54 files
In the WorkSpace\TriForma\ArchDatasetNcsUS\data, there are 64 files
But in the WorkSpace\TriForma\ArchDatasetANZ\data, there are 3 files.
Does the ANZ Dataset look somewhere else for these files, or is the Dataset actually missing the files.
This might explain why the Beam and Stair commands aren't working. The Beam command comes up with "No beam sections are currently loaded, Please select one". And the Stair command crashes BA because it can't find a stringer name.
Brian Thomas, AIA, LEED AP BD+C
GH2 Architects
The following Bentley Architecture datasets (versions 08.11.05.54) are now available with a network install option (as in versions 08.09.04 and before) from SELECT downloads under 'Enhancements and Updates'.
Others to follow as soon as possible.
Volker Thein [Bentley]
