We have a project with multiple users, all of a sudden our room labels areas are in sq.mm instead of sq.meters.
Preferences settings are as follows:
Any ideas on how to fix the units to read square meters?
ABD V8i SS6
Serraric,
Look at your Design File Settings
and set your Working Units - Master Unit to Meters.
Let us know if this sets your spaces correctly.
Larry
Answer Verified By: serraric
Wouldn't you untick Using Working Units. It would then use the next setting below it.
Untick 'Use Working Units' in everyone's preferences, then you can set m as the default.
Marc
Yes, you can also do that.
Thanks MickyKom and Marc.
+1
