Hello
I'm a New user to your program AECOSim SS5 V8i as my experience was only on Revit (I'm BIM/COBie Specialist Engineer) , but my company is forcing me to use it coz the whole Arch. and Structural model from the designers were designed using this program
Despite that its a non user friendly interface (no offense ) , but since i started operating on it , it crashes a lot
when i try to modify elements it works, but some other times it just lags and give me the (Not Responding) term in the top of the screen and it hold still like this for ages
this thing happens when i just try to modify elements and add instance data in order to be able to export the IFC and COBie spreadsheet
anyone knows what shall i do ?
Hi Mahmoud,
Looks to me like you are working on a large file. Can you please confirm whether you have tried changing the view style to Wireframe before doing the operations?
Satadal.
No dear its not a large file
its only 8 MB
and yes i did all of that and even deleted everything and started just tried to place those components that i wanna edit or modify and still same problem (i.e. doors )
lags and crashes eventually
Just to clarify, does AECOsim display (Not Responding) when:
Are any/many reference files attached?
Marc
Hi Marc
yep all of the above you've mentioned
and no this is for no references attached also
i reinstalled the software
i even created a new user on my company's dataset
and nothing , just crashes
thanks
Are there :
Any error or warning messages in the Message Center (shown towards the left of the status bar, please see help for more about it) immediately after opening a file?
Any error messages during after the crash?
