When using Dynamic Views in mechanical services, i am getting pipework corruptions where the pipework that has been cut through appears much larger
it seems the only way to avoid the curved lines running through the drawing is to turn off the pipe level leaving just the insulation.
is there a better way to fix this problem or is it just another nail in the dynamic view coffin?
I am using SS6
David Turner
MEP 3D coordination & BIM Technician
Rail Projects
