I am new to the software and I am trying to update our office setup to the Connect Edition. I appear to have got it to create the Worksets in the right folder and read from our file storage folder but get errors when opening a dgn file. This the message center errors, any ideas where I am going wrong?
OK I have managed to get a bit further as I had incorrectly placed my dataset folders, this is what I have now and I am not sure where to go from here.
Hi Jonathan,
I would suggest you to go through the following blog once and try to do the setup.
CONNECT Edition - Configuration : Customization Guides
Subhamoy
Warm Regards,
Subhamoy Kundu
In addition to the guides mentioned by my colleague you should find Bentley Configuration Explorer useful to find out what is going on. Anyone needing the latest version should ask via a Service Request, we will then be able to send a download link.
Marc
Thanks Subhamoy,
That's where I started but may have gone wrong somewhere so will start at the beginning again.
Cheers
Hi Marc,
Thanks for that, is there a way t get it to pick up my network install?
It only appears to see the standard install only.
Jonathan
