Drainage Modelling
I'm just about to model quit a large exisiting drainage network.
Can anyone point me to any resources that will help me with workflow, tool choice and tool use ?
Thank you
  • Hi Fraser - you should post English language queries into the English language forum for the speediest response. I have moved your post there. Someone will get back to you shortly.
    Duncan Brown
  • Hi Duncan.
    Nobody replied.
    AECOsim v8i SS6 08.11.09.866.
    I just wanted to place some pipes by two points (invert levels)
    I need to set the inner and outer diameters.
    It is just a simple model at the moment.
    I'm using "place pipe"
    In the "dataground instance data" box I can change the outer diameter in pipe parameters but not the inner diameter.
    Are there no step-by-step guides to this ? It should be so simple.
    I should say I am working completely alone with no support and no other input.
    I am not comfortable with modifying the dataset today as we are rushing to make a deadline.
    Bentley tantalise me with tools and utilities which I find impossible to use when I start to look at them.
    Step-by-step quick startup examples is what I need. I've even looked on You Tube.
    As usual, typing "place pipe" into online help is a complete waste of time.
    Thanks.
    PS There is something called Diameter 1 but it seems to be locked to the same value as outer diameter.
  • Hi Robert
    Thanks.
  • Hi Fraser - see below. Robert replied to your query.
    Duncan Brown
