Just wondering is there Extraction operation available in AECOsim Connect Edtion like previous version. If yes could you show me where it is.
Hi Shashi,
Drawing Extraction is no longer available in AECOsim Connect Edition.
The V8i Drawing Extraction Manager has been superseded by Dynamic View based drawing production. This is discussed in the Drawing Composition section of the help documentation.
Searching for 'Drawing Composition' with Bentley CONNECT Advisor will offer direct links to the relevant learning videos and other resources.
Marc
Hi Marc,
Thank you for your confirmation that extraction is no longer available in connect edition.
Thank you Gerard for your confirmation.
Hi all
It's great that DEM has been depreciated / phased out, but how is it possible to upgrade an extraction to a DV in CONNECT? We have a number of files which contain drawing definitions that need to be recreated as DVs, but it seems there is no longer a way to this. How can we tell where previous extractions were created, which are missing from the new DV definitions and which still need to be recreated? Do we need a parallel copy of V8i installed to achieve this?
