I added some new parts in plumbing by example, airflow properties never change ! it always keep my last airflow !!
In my case Airflow stay in medicalgasnitrogene...
I join a shotscreen
thanks
Can you make sure that the Air Flow property in the DataGroup Catalog Editor for the item that you are placing has the value that you want to assign?
Satadal
In my DataGroup Catalog, Editor the airflow field is empty !
see you soon ...
Hi Joel,
Please use delimiter like "-", in a part name, 'underscore' would not work. Also, there is a fix made which will be in update3 build i.e. it works with 'comma & colon' in the part name. Please refer the below snap
Answer Verified By: Steve Cocchi
Hi Latif,
Perfect !
Thanks you
is there a possibility to change the values in "status" and "air flow" after placement
I thought the change was automatic when I used "apply part"?
