Hi you all
In ABD Connect Edition where is the classic delete opening tool we have in SS6? When I create an opening onto a form with a shape how can i delete it if i don't want it anymore?
I can't find it in the ribbon. Lot's of thanks
Borja
You can always right click on the element and select Building Element Info > Features. Select the opening and delete it from the Building Element Info dialog box.
I have consolidated this in form of this WIKI
Hi Borja,
Is this what you're looking for?
I haven't used this yet in CONNECT myself, but found it using the Search tool: https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/35852/connect-edition---what-is-the-easiest-way-to-find-the-tools-i-need-in-the-connect-edition
Answer Verified By: Steve Cocchi
Lot's of thanks
I'm glad that helped!
