I have floor levels set at specific elevations, for some reason certain elevations are not at the level it is supposed to be once the elevation datums are generated!?
T/o North Exhaust Structure Roof 178850 is where it should be, but the Main Entrance FFL 171575 is shown about 24 metres below.
Why is this happening?
serraric,
Which version of AECOsim Building Designer are you using and on which Operating System?
Also, if it's V8i, In Settings - Design File - Working Units, what is the Resolution value you are using?
Larry
ABD V8i, windows 7
What is the exact version number i.e. 08.11.09.xx?
Can you generate an elevation for Bus Terminal Platform (LP)? I'd like to see where that is located in relation to Main Entrance FFL since they're the only two floors in that building.
