Been having this issue for months, a few specific files (design models) constantly keep getting locked out even when nobody is working in those files directly. When I click on the write-lock check mark and hit OK to release it....nothing happens and the check mark remains. We constantly have to wait until the write lock gets magically released in which we can actually make modifications to that design model.
This has been a big issue and hoping to finally resolve it.
Using AECOsim SS6 V8i
Do you use the reference activation feature?
If so when files are deactivated they remain locked until either the active file from which they are activated is closed, or the release write-lock option is selected from the active file. This is designed top allow people to retain control of a reference file while making a series of edits to the reference.
Marc
Answer Verified By: serraric
