Hi there, I'm trying to Detach instance data on a beam created from a solid, using the Detach tool but it deletes Family and Part info but doesn't delete Datagroup name and catalog. I can see it in the Building Element Info dialog.
Process: I first created the solid (curved "beam"), then I used Attach tool convert it into a catalog beam with Datagroup info, and when I want to modify datagroup data I cannot do it because "the element already has instance data".
1.- How can I delete ALL instance data from an element created this way?
2.- How can I apply Datagroup data from an element to my "USER" element?. Using Schedules only works with APP elements, not with USER elements.
Thank you
Hi Sergi,
FWIW, the V8i keyin DG MODIFY DATA included in the Wiki Eduardo mentioned above still seems to work on extruded solids.
