Hi all,
I've been trying to figure out the best way to create a Grid System for a train station.
The floor manager needs to be set up in order for the Grid Systems to work. However this does not enable inclined planes, a requirement for our station.
In addition to this, when testing the Grid Systems using the Sketch feature, the lines of the Grid seem to be hidden behind the graphics within a Dynamic View.
Obviously this is not ideal as a lot of manual drafting is having to be undertaken to overcome these problems, and at this stage I'm tempted to give up with Grid Systems completely and revert to manual methods.
Any advice??
Grace Newey
Hi Grace,
When you create the Sketch Grid try using the Create Grid Line from Element to use that specific inclined as the grid guide line, let me know.
About the Grid hidden behind the Drawing View, could you provide an image or a sample file?
