DRAWING TITLES IN CONNECT EDITION
We made extensive use of the place title function for labeling references in V8i.
This seems to be missing in the CONNECT attach reference dialog.
Hopefully titles with linked references are still possible-- where are they now?
Couldn't find it in the help.
  • I forgot to say select properties from the menu. That's strange that it sometimes shows no properties. When I tested it I created a Saved View in a master model (an isometric with a clip volume applied to try and get a 'cut away' looking drawing) and used the saved view option as the Orientation option in the Reference Attachment Properties.
    What orientation option are you using? Just trying to think of how different options might affect the drawing title properties.
  • Paul-- it is intermittent.  Sometimes you can select normally, and the properties are there.  Sometimes right press will do it.  At other times it says No contents to display.
    We create, say, a floor plan in a master model, as a saved view, then create a 2D drawing model in an already existent sheet file.  After clipping and masking the 2D model, it is referenced into the Paperspace of the sheet file, where the drawing title is created.  Here is where we have the intermittent problem.  The titles are edited usually only once, but it is still puzzling, this problem did not occur in SS6
    dmg
