Space frame detailing
Dear All,
Anyone can help me to modeling the space frame in AECOsim or ProStructures, with connection as picture below. I upload one drawing with autocad file model in 3d for refer
REF.dwg
  • Please can you confirm the purpose of the model, is it for structural analysis or design coordination?
    Marc
  • Dear Marc Thomas,
    This model will be use for fabrication include
    - The single part of beams
    - BOM
    - Detail for any sphere
  • I'm wondering if this is a job for generative components? I did create a model, reference your dwg, used structural hex and hollow tubes and sphere solids. If I knew that I could copy a section of it to fill in the same configuration of the modules of it I would have gotten a lot more modeled.
    So just to model it 'by hand' might take awhile, and some care, but it's doable. I'm not sure about the beams, are they a hex all the way through with a hollow tube around them, etc.?
    Then I'm not sure the method I used gets the fabrication results you're needing, but if you take a look at the schedules utility—that's the information I'm getting reported.
    I used AECOsim Building Designer CONNECT Edition Update 2. Metric units, AU steel table. I spent about an hour (had to move on to my other projects), looking at the photo, thinking about how to model what I thought it looked like, then doing the modeling, basically tracing over the lines in the reference.
    It would be good coordination with other disciplines.
    Framing Test.dgn
  • Dear Paul,
    Thanks you so much for your reply. In your model the connection made is automatic or manually? Can you show short tutorial for it?
    About the fabrication data I needing are
    - for beam frame elements: BOM with position, cut length, weight, single part drawing ( if need )
    - for space node connector: angle of frame connected to node for all node in model result in excel.
    Thanks you so much
  • I did that manually. I'll get a video done, might take me a few more days to get it done. I think we can get the position, cut length and weight. I don't think we can automatically get the angle of the frame connected to the nodes (the spheres I used in the model).
    I'd have to try the single part drawing, we can generate drawings from the model, I'd have to see what the results would be in a model like this to get single parts.
    Anyway, I'll see what I can model and report, but again, give me a few days.
Reply
