Using Aecosim V8i,
We have been using a particular space label for room labels annotations, we have made a slight change to that same space label (separated room name, number and area on different levels).
How can we push this through out the project without affecting the position of previously paced space labels. when we refresh annotations, the space labels tend to move to its default position (center of the room).
Hi Serraric,
Off the top of my head, I'm not so sure you can. I believe refreshing annotation essentially regenerates it, using the default rule based location in the process.
We may have an Enhancement filed for the ability to "lock" the location of annotation, but if so it would be best if you could file a Service Request so that support can link the two, adding weight to the request.
