Settings file modified by another user, error creating settings.xml
the solution TF_DATASETNAME=Dataset_XX in the CFG file doesn't work on my system.
What else can I try??
Hi Marc,
Have you defined the variable inside the cfg file of every workset ? The default location should be [ C:\ProgramData\Bentley\AECOsim CONNECT Edition\Configuration\Datasets\Datasets_Name\Setting folder ] Make sure you have the permission to that location or similar in you system.
Hello Ranit
strange my worksets cfg.files are standing local on the folder before my projects. I adjusted all the cfg.files but still no result. It must be more in my case.
kind regards
Marc
Update from Bentley Communities Ranit Deb Hi Marc, Have you defined the variable inside the cfg file of every workset ? The default location should be [ C:\ProgramData\Bentley\AECOsim CONNECT Edition\Configuration\Datasets\Datasets_Name\Setting folder ] Make sure you have the permission to that location or similar in you system. View online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here. Flag this post as spam/abuse.
View online
Are you using ProjectWise? If so, then what is version of ProjectWise that you are using? What is the version of AECOsim that you are using?
This could happen if the Workset configuration file or the Project Configuration file (depending on the version of AECOsim you are using) is somehow corrupt. If you have a default workset, then I would suggest you to try copying the contents of the configuration file of that Workset and then paste it into the configuration file of your current workset. If the two worksets doesn't use the same dataset, make sure you choose the correct dataset name in the dataset declaration in the configuration of your current workset.
Please let me know if it helps.
Satadal
Are all of the required sub-folders present in the WorkSet Standards folder?
Update from Bentley Communities [AUTOMATED MESSAGE; if there is a link below, please follow that if you wish to respond to this Communities message.] RE: Error settings.xml Marc Thomas Hi Marc, Are all of the required sub-folders present in the WorkSet Standards folder? Did this answer your question? Verify it as the answer or Reject it as the answer View online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here. Flag this post as spam/abuse.
