I have worked on model extraction file and closed the file. next day when I opened the file and found that tags are missing. does any body know the cause of missing tag.
if any body know please help me on this.
regards
Sanjay
Which version of ABD do you have installed? Are you using Drawing Views or Drawing Extraction? So the annotation in the extracted or drawing model is missing after you manually annotated the items or were they automatically annotated?
I have been using ABD (v8i Select series 6) and drawing extraction has been used. tags are missing in extraction model. annotation has been done using tag command.
I also facing this issue in my drawing model. I have off the Auto Annotation, but still the same. Have any solution now?
OBD update 8
