Hi
I wonder how to define this properties:
GUID, Locked, Description, Layer and Element ID
to be included in a separate pset in the IFC export?
Example from my IFC_Mapping_overrides.set:
"Length" : "IfcPositiveLengthMeasure" = StructuralQuantities/@Length# "ObjectID" : "IfcIdentifier" = ObjectProperties/@Element ID ObjectProperties should be = ________??
"BSAB-E" : "IfcLabel" = ObjectClassification/@BSAB "Comment" : "IfcLabel" = ObjectIdentity/@Notes# "TypeDescription" : "IfcLabel" = ObjectGeneral/@Description ObjectGeneral should be = ________??# "IfcGUID" : "IfcLabel" = ObjecProperites/@GUID ObjectProperties should be = ________?? "TypeID" : "IfcLabel" = ObjectIdentity/@Mark# "Locked" : "IfcBoolean" = ObjectExtended/@Locked ObjectExtended should be = ________?? "FireRating" : "IfcLabel" = ObjectFireResistance/@Rating
Cannot find this properties listed in the definition editor and when I look in the actual model there is listed as above (marked with yellow). Example:
Best regards
Anton
Hi Anton,
Working with BIP was discussed a while ago, do the suggestions made in either of the following posts help?
The first (scroll down to Igor Solokov's comments) talks about adding PROPERTY_SET BIP:
https://communities.bentley.com/products/building/building_analysis___design/f/aecosim-speedikon-forum/114598/pset-and-floor-manager-to-ifc
further comments are made in:
https://communities.bentley.com/products/building/building_analysis___design/f/aecosim-speedikon-forum/127422/concatenate-labels-pset-export-to-ifc
Marc
[AUTOMATED MESSAGE; if there is a link below, please follow that if you wish to respond to this Communities message.]
RE: BIP - IFC pset
Did this answer your question?
Verify it as the answer or Reject it as the answer
View online
You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here. Flag this post as spam/abuse.
The GUID is a dataGroup property generated by the application, we have recently enhanced IFC Export GUID stability so the GUIDs are consistent across versions when the same elements are re-exported.
Layer (DGN Level?), Element ID, [Element] Description and Locked are all DGN element properties generated by the application.
What does your DataGroup Mapping for these components look like?
