Hi All,
I am using :
I have a drawing file which was created from a saved view in a composition file but can't figure out way the look different. There is a wall in between the stairs so I shouldn't see the stairs behind the wall (as shown in composition saved view):
In my drawing file (created from saved view above), the wall appears to be transparent??
Please help.
Hi Serraric,
Can you please attach the file over here so that we can investigate in our end.
Warm Regards,
Subhamoy Kundu
Some things I can think of:
- is the level with the wall visible in the drawing?
- isn't the wall on Construction Class?
Windows 10 pro
OpenBuildings Designer Connect Edition Update 10.10.01.151
In addition to the questions above - is that first image the Saved View used by the Drawing only applied directly to the 3D Model instead? If so, then yes, they should look the same. However, keep in mind that Drawing Model presentation settings can be changed independently of the Saved View itself, so technically they could look different...
